TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Wet driver side carpet
ZTom
on March 17, 2015 at 10:53 PM
posted by Zuberman
on March 17, 2015 at 10:42 PM
Yes foregot bout that and also with the Z overheating your thermostat could be stuck close. Check the upper and lower radiator hose it should be hot to touch when the coolant is circulating throughout the engine.
L£AÐZX
21:12:58 03/17/15
Re: you should only use water as an emergency
ZTom
22:06:15 03/17/15
Zuberman
22:42:28 03/17/15
Re: Re: Wet driver side carpet -
ZTom
22:53:48 03/17/15
L£AÐZX
23:49:27 03/17/15
Re: is your Z TT or NA (n/m)
ZTom
23:59:45 03/17/15
Heater core ?? (n/m)
ttz'in (norcal)
00:01:57 03/18/15
Water temp 210 - 220 ish. Add 20-30 for oil temps (n/m)
ttz'in (norcal)
00:04:16 03/18/15
Its a 96 twin turbo
L£AÐZX
00:21:57 03/18/15
If you have a bad heater core losing system
ttz'in (norcal)
01:54:40 03/18/15
Re: If you have a bad heater core losing system
L£AÐZX
02:20:49 03/18/15
Apologies. Just don't want things to get worse. (n/m)
ttz'in (norcal)
03:41:52 03/18/15
Re: at start up the AC will be cold
ZTom
10:25:14 03/18/15
